Water in floor after car wash
diesel_lv
11:33 PM
Arizona
I am assuming that this is exterior related. The car has been parked over 20 yrs and is now being brought back to life. The last time I took it through a car wash, 1998, it ended up with water in the floor board up front. I am thinking 2 possibilities, wiper shaft or fresh air vent in cowl. Any thoughts would be greatly appreciated. 1967 Dodge Coronet 440 4dr.
Pull the fenderwell splash panels and clean all debris.
wiper seals, cowl vents plugged, windshield gasket leak.
All of the above. Time to refresh those areas. Also, look at windshield seal especially on the lower corners
I would clean all the areas from debris then do a hose test, starting with the lowest areas first, on the side that leaked. Have someone on the inside watching for the first signs of water coming in.
:thumbsup::thumbsup:
Thank you everyone for the replies. Once I get her shoes back on her, I'll do the leak tests. In the mean time, I'll replace the wiper seals while I have the gloves box n instrument panel out.
