If you can get it fro $4000 or less and need sun roof parts. I can help, I have a 74 Triple white charger with a sun roof. I purchase spare parts whenever I find them. There not cheap. I plaid hundreds for them. Alo do not attempt to operate the sunroof, you will damage the drive gears and cables. remove the cassette for cleaning and inspection. typically full of dirt and grime. It comes out as an assembly. The bad news is the sunroof is missing the drive gear and related cables. I have a friend who can clean and recondition the unit. But you will need the missing parts. Add a $1000 to your price to rebuild the set-up. Send PM if interested.
Also don't take his word on being a 440 car, check the block. Also consider patching the roof with a doner top. I have one complete from another project. If you need other parts, send PM. I maybe also be parting a 74 this spring. I also have a 78 dodge magnum with an sunroof, but the top opening is different. Some of the parts will fit from an newer model, but not the complete unit. Just more bad news.
