Emblem removal
BeeKool
2:31 AM
Iowa
Parting truck out.
Wish too remove in w/o damage.
There are no studs, glued on I assume.
Any tips or tricks?
Fishing line to remove emblem , stretch between both hands , wrap around fingers if needed , use sawing motion with fishing line behind emblem
5 minute job with those small emblems
The leftover residue on the paint usually takes the most time , but it sounds like you just want the emblems anyways
I’m pretty sure someone posted a thread about the very same thing yesterday. I de badged my 2018 ram after I got it. Used a heat gun to warm it up so the emblem was “movable” THEN used dental floss to get in behind and used a sawing motion with it. Also helps to have a second person to hold the heat gun on it while doing it. Can get most of the glue off by peeling it by hand, then I used an eraser wheel to get the left over residue
Wd40 as a lube then a thin putty knife working it downwards gently tape the blade so the corners don’t gouge the paint
If,you don’t care about the paint just use a scraper and some heat.
Heat gun to remove the emblem. Goo Gone to remove the glue, if you want the sheet metal clean.
Heat or floss. Then wax and grease remover
