My 70RR doesn't seem to be getting power to the ign nor the starter
The big red wire on the starter relay has constant power with key on or off as well as the fusible link. The big brown wire has no power when the key is turned fully.
The starter works when i short the brown and red on the relay
With a testing light the coil or ballast don't seem to get power with the key on.
Outer connector block is new, don't know about the interior one. Wires in engine bay are new as well as the ignition switch
Before this happened i pulled the fuel tank because the new sender was barely reading at all. I removed the sender, attached longer wires to how it was in the tank so i could watch the gauge as i moved it. When i did that it was reading all over the place and then just goes to far right. I gave up and installed sender back in tank and tank in car.
When key is on it goes straight to the far right.
I don't see a connection but thought i should mention it
