SWAVE0424
I have a '73 Satellite with front discs and rear drums.
The stock wheel size is 15x7 rim with 5x114.3 bolt pattern.
Stock Tire size is 215-70R15 with overall diameter of 26.9 inches.
I want to go to a 17 inch wheel. Preferably the Center Line MM6MB 635MB.
17x8 - Bolt Pattern: 5x114.3 | 5x4.5 | 5x4 1/2 - Offset: 00 mm.
Tires will be BFGOODRICH G-FORCE COMP 2 A/S - 215 /50 R17 with overall diameter of 26 inches.
I guess my concern is the little extra width, from 7 inches to 8 inches.
Anyone think this will be a problem?
Also, since the overall diameter will be .9 inches smaller, there shouldn't be any other issues, should there?
Will the offset of 00 mm be OK, shouldn't be any issues there, right?
I think the hub bore size is 73, so I do not think there will be an issue with that.
Anyone know if there will be issues with this 17 inch setup?
Hopefully it should just bolt right up.
Any help is appreciated.
