You're going to want to tack a plate/plates on that front edge so you can pull on the several points at once. The bumper pushed it in almost like a forming die. Heat the tight creases first. It's going to take a little time. I'm thinking a combination of a plate on the edges so you can attach a porta-power or come-along and the pins in those deep spots.
Had a fender similar to that on a 72. We Used a porta power with a clamp bolted on the leading edge. Chained the car down, heated it up and pulled it out to where it was almost perfect. You will never get that out with a stud gun puller. It is a very strong area...
