Smokinnjokin
Gentlemen, I'm having a tough time figuring out the correct spring location and cable routing to provide proper return to idle and full travel.
Currently, I have the spring hooked down here because if i hook it to the bracket, it is way too high to provide good strength to close the throttle. If i use a stiffer spring, the throttle will close properly in the top position but the pedal is ridiculously stiff and does not want to reach WOT.
I also have a rigged throttle cable, it works and provides full travel but the OEM bracket ('79 360 smog motor) is not a great fit. Need to move the cable farther from the carb and the bracket can't move any farther.
Any ideas for my proper P/N spring, return bracket and cable brackets?
