matthon
A novice in electrical testing looking for advice on what to test for above issue, have meter, test light. More details below if needed.
Saturday, went out to start, power but not enough to crank it over.
The alternator came off of a running car, but used, had coupon, so I figured I'd just replace. Put battery on charger, went to get alternator.
Replaced alternator, car fired right up, drove it to run errands.
Not 100% convinced it was the alternator, decided to replaced dimmer, as it would stick and I had a new one, and bypass ammeter.
Ran new charge wire/fuseable link from alternator to starter relay.
Black wire from alternator to bulkhead removed.
Original red wire from starter relay moved to where black wire from alternator used to be on the bulkhead connector.
Disconnected black wire at ammeter.
Ammeter red side had power seat connected there, which then goes to a circuit breaker.
Spliced black wire and red for power seat.
Car started fine, everything worked, test drove, put in garage, turned battery disconnect on negative side, out of habit from leaving it sitting over the winter.
Sunday, started right up, went out, ready to go, power but not enough to turn over.
Got a jump, got home, turned lights on, died.
Jumped again, idled fine, went to get meter, sputtered and couldn't keep it running, died.
Jumper pack out of juice.
Pulled bulkhead apart, looks fine, car is fairly original, and wiring is in excellent shape.
Charged an hour or so, started right up, 12 volts at battery, all electric items work, lights, seat, rear window, fan, no radio.
What do I check to find what is draining this battery?
All items new at the end of last year:
Battery, pos/neg cables, voltage regulator, starter relay, starter, msd dist/coil, eliminated ballast resistor.
Negative cable grounded to engine, paint removed first.
Positive cable with new solenoid wire ran inside heat resistant sleeve away from header.
Battery on trickle charger all winter.
The only thing I didn't replace is the horn relay and the headlight switch, they work.
