Understood....but that does not look like an OD, which is why I was researching the one in my pic.....Not sure what that one is out of, to be honest.
For your 383 Runner, you'd need to find a 23 spline A833 similar to this one.
Although this one is for '70-up (note the additional rear shifter mount), otherwise this is the critter
you need. Note the rear mount, front mounting ears and where the speedo output is as opposed to
the one you show:
Thank you
Thanks! Appreciate that....its in a local ad, and was hoping for an overdrive that would fit RR to alleviate some if the highway "screamin"!Not sure if you know this....and you might so not harm meant, but the OD chrysler trans uses the same exact case and tail shaft as moparedtn posted (4 speed A833 case/tail) except different internals. Bigger front bearing retainer and flipped shift lever are signs of the differences. Wasn't sure if you were thinking the OD unit was totally different or just trying to see what the one you have came out of. No biggie if you know that, just tryin to help. That trans in your pic will not bolt up to any mopar bellhousing from the 60's/70's muscle car. My 78 PowerWagon has a similar bolt pattern, but that would be a 4wd truck bellhousing so that wouldn't fit your application either.
Thanks!You can find them around from mid seventies and up 2wd pickups and cars. They will have the bigger front bearing retainer, and the 3-4 shift lever will be flipped and pointing down as opposed to a true 4 speed where both shift levers point up. Theres other ways to spot them, but those two are a start. Make sure its the long tail shaft version too if you are sticking it in your Roadrunner.
