Has anybody used wire glue? This is supposed to be a heatless alternative to soldering. I've done some sifting on wire glue and for the most part, the reviews are positive. The gas and temp gauges are out and finally discovered a broken wire trace on the circuit board. It's the sort a situation where heat soldering could create other ills so pondering on this approach before I end up heat soldering or buying a new board.
Thanks.
Thanks.
