Just set up. 489 case, Cone SG unit with a small yoke. Lightly used gear set with all new bearings, crush sleeve, etc. 3.73 ratio. Ready to drop in. Asking $800.
We can talk about shipping options from 16602 or possible drop off to local shows.
It has a brand new crush sleeve in it and the pinion bearing preload was properly set. Yes, you could switch yokes to the bigger one BUT the better choice would be to buy the combo U-joint that will accommodate the smaller size yoke diameter.
