I dont think there the same.. the front lip moulding will have a black color strip in the middle on the Plymouth.. The coronet wont.. I could be wrong..
It won’t go on, it mounts different.
Coronet mounts with studs and nuts running front to back.
Belvedere mounts with screws from the bottom up.
If you compare 1966 to 1967, and Belvedere to Coronet it is all different trim.
1967 Belvedere can have either black or white paint in the recessed groove, 1967 GTX and
Satellite had dark textured argent in the recessed groove.
