Hi Folks, anyone know what paint to use on the steel part of my dash (which is black) and where i can get it? I now is a dull paint as not to reflect the sun. Thank you in advance.
You could use ppg 2 part and add texture from ppg. The dash needs UV protection. How good of a job do you want? If you go PPG your looking at 340.00 for paint for dash and steering column for base flat, second coat add texture then 2 coats flat clear.
