Had posted some about my engine temp being too high and got a lot of good advice as usual on our forum. Did a lot of things to cool it down and it worked though still wondering about the higher op temp aside from the hepped up things done that impact cooling. Anyway, had been running 20/50 high zinc oil (solid lifters) as that was the only high Z oil I could get at the stores. The oil psi was always real high so prompted me to ordere 10/30 high Z. I found a dramatic reduction in motor temp. Reading some on this evidently experts say running a lighter weight oil dissipates engine heat better due to faster oil flow. And additives today generate a stringy effect as the oil heats up to cling to lubricate the internals. I had thought the heavier oils would have less breakdown in viscosity; but not so much versed on the affects of engine heat. Anyone having experience with this, curious to hear your thoughts. Thanks.
