This is for a Sport Satellite actually. But I believe all three are the same. If I am not mistaken only the Sport Satellite and GTX used honeycomb plastic grills! Also the GTX chrome was the same as the Sport Satellite being ever so slightly higher end cars.Make sure it's from a RR/SAT as believe it or not GTX is a different piece..
Oh ok thank you.The Sport Satellite & Gtx grille used one set of trim while the RR/Sat used another. The trim is the same looking but a different length between the 2 style of grilles. I have one of those trim pieces from a 70 Gtx/S Sat grille and one from a 70 RR/Sat they are different. I will show you during the week the difference...
I have a piece of that chrome. I'll take a pic when I get home.Need the top piece or chrome for the center section of the grill. Arrow is pointing at the missing culprit. I do know I will need to figure out how to secure it as the plastic tabs have been broken off.
Thanks
MF
Thank you QBp! ThaLooks like this guy is helping you so I don't need to go any further... If it falls through I do have the correct trim.
Awesome thanks!I have a piece of that chrome. I'll take a pic when I get home.
Thanks QBp!Looks like this guy is helping you so I don't need to go any further... If it falls through I do have the correct trim.
