I usually avoid commenting on these types of statements as it usually turns into a circular discussion on the opinions of what folks think.
Agree. Also with most of your other statements.
3) Because of gerotor pumps are positive displacement pumps, volume continues to go up more than what's pumped to the engine through the relief valve (otherwise pressure would go up even more) requiring a lot of work by the pump.
I don't fully agree with all of this one.
Yes, volume can easily be increased. Again, it depends on the engine's clearances. That creates pressure, along with the pressure relief valve. Adjusted as needed.
Nope...not trying to make any claims, going by past experiences...on radial engines!
Why?? Same principals, basicly, same parts and pieces, all needing oil pressure, and volume.
Auto engine's crank journals, vs bearing clearances, usually fairly close. Radials are completely different, but still need the oil, both ways.
R-1820 radial...crank has ONE rod journal, to service nine cylinders. The one rod bearing (one piece), about 4" wide, about 4" diameter, the measured 'clearance' from bearing to journal, is only 1/2" wide, in the center of the bearing. Tapered wider at both ends. So what?
Takes oil pressure, to keep that small area separated, along with the volume. Point is, pretty much nowhere in those engines, including that bearing, that creates pressure. All free flow.
Only the pressure relief valve creates pressure, the restriction it creates.
But, the thinking is there. Done.
