Melling M63HP
TrackPack
3:01 PM
Minnesota
What color spring is the Melling M63HP pump supposed to have? Thanks.
Well.....I know that it isn't red, and it isn't black.....
Not sure... But here is a nice read on pressure vs. flow:thumbsup:
Isn't the natural metal spring considered black as opposed to painted red?
I just had an HV apart, but didn't think to scrape to see if it was paint. Sure looked black though.
I'm not sure if the red spring/black spring is till a thing. I have three or four M63HPs at home. I can check, but not sure when I'll be back home. I recall them to be natural as well. You didn't ask, but FWIW, it runs about 70 psi.
all the stock or aftermarket high pressure springs I have or seen were either plain or black. stock standard was always red. newer aftermarket stock pressure pumps may have red or pink. anymore I just measure the wire diameter of the spring. not as straight forward as it used to be.
