PurpleBeeper
OK, I've read about a half dozen posts on this and I'm stumped. 1970 Roadrunner with a factory fuel tank (99% sure it's original). The fuel tank has an aftermarket "dual outlet sump" on it, so fuel goes out those two outlets & the original fuel line at the sender is capped off, but the sender is still hooked up to operate the gas gauge. The car sets just about level...maybe 1-degree nose up. The gas gauge reads a little less than 1/2-tank when the tank is completely full. Here is what I've done, in order:
* grounded the sending unit wire & gage pegged FULL
* ran an extra ground wire to the sending unit "ground strap" to the body of the car (since it has aluminum fuel line)
* installed a new aftermarket sending unit
* replaced the aftermarket sending unit with a working used original sending unit
* replaced the gage itself with a new reproduction gage
After all that, the gage still reads about 1/2-tank when the tank is completely full. There has been a tiny bit of variation, but the gage reading is off by just about the same as what I started with. The only piece that is original now is the wire between the sending unit and the gage.....what the heck am I missing here? How critical is the resistance on that sending unit feed wire? If I've got some type of patch job on that wire (likely) would that throw off my gage a lot?
