signalsparks
Greetings, one and all. I'll start with my problem, and then tell my background.
Problem: I disconnected the "C/LTR -- DOME L" fuse so as not to drain the battery while performing maintenance on the front passenger door (repaired window mechanism) -- went to plug it back in, the fuse blows instantly. I'm going to try disconnecting the battery and replace the fuse again, but while the burn blister on my finger heals...
Any thoughts? Known issues? Places to start looking? Dome/map/steering column lights still work when the engine is running and the door is open. Haven't checked the lighter.
Instead of posting my life story here, I'll make a separate thread in a more appropriate forum.
Thanks in advance.
Thanks in advance.
