Paul_G
- 10:30 AM
- Dec 24, 2013
- Surprise, Arizona
The radiator had a bad leak. No coolant in the car when I got it. Filled with tap water and found the leak, then fixed it. I suspect someone put some stop leak in at some time in the past. The water has been black, stayed black, even after several radiator drains and refills. I finally got the water to run clear.
