I’m not positive, but I thought most factory cars placed this filter between tank and pump but with the filter as close to the pump as possible. This is where mine is now and no issues. I have it down low below the passenger fender apron somewhat away from engine heat. What you say about between pump and carb does make sense though.
I found an old FBBO 2012 thread on this. If you want the filter with the vapor return line coming off at a 90 degree it’s Wix 33054 (5/16”). Not sure for 3/8”. Install between pump and carb with the vapor port facing up is what the thread recommends.
My 2 port in line filter is between tank and carter mechanical pump on passenger side and never had a problem. Doesn’t look like much room to install between pump and carb without it living in front of tbt air cleaner...
https://www.forbbodiesonly.com/moparforum/threads/what-is-this.39825/
thanks for that. I had no idea some of them internally would be different as well. How to know without x-ray or cutting one open if it's a good one? I guess in this case it doesn't matter if the return port is facing a particular direction? Do you have the part # for the year one part? Is yours between pump and carb or between tank and pump?I differ on the orientation of the vapor port, IF it is a mopar designed one. I can't speak for the Wix. When I read the same thread, I quickly looked at my Year One vapor separator and made sure it was orientated correctly. I believe it is. Here is how the Mopar designed one should look. I don't know about the "other suppliers", but I know that Year One is twice the money, but research of threads on this site and others seem to suggest that the cheaper ones are not make the same. i.e. some without screens, some with to big of orifices, some not welded to withstand the vibrations. No complaints on the Year One separators.
Thanks very much for all of your efforts and info. I also have a large diameter 100 micron stainless filter back by the tank. The small vapor port filters we originally brought up are about 1.25” diameter. Is the year one vapor separator larger? It seems like it would be. What you say about vapor lock being addressed between the pump and carb makes total sense. I need to dig up the service manual to see how to locate it there.Here is the url for the vapor separators from Yearone. My car and engine is a '67 and I ordered the '68 one (first one). Don't really know the difference, but call them and they will gladly let you know.
https://www.yearone.com/Catalog/chrysler.b.body/air-.-fuel/fuel-filters/vapor-separator
Definitely whatever you install needs to go between pump and carb. The thing you will need to verify is if the 1/4” return port has the .060” diameter orifice so the vapor can bleed off but maintain fuel pressure to the carb. If that inner diameter is too big you won’t have enough fuel pressure. Since reading that the others here had good luck with that year one separator I have since read other reviews of that online where the year one unit didn’t work correctly because of that issue. You’ll need to check whatever you buy. YMMV. I bet the wix pieces are good as most of their stuff generally is.Going to install a vapor separator on the Dart, 360 crate motor. Obviously not original so I'm going with the Wix 33040. Not knowing the quality compared to the YO repro, should I keep the canister fuel filter inline between the pump and carb?
Don't know about running it upside down, but I wonder if the separator has to be that low or close to the fuel pump or if it just a matter of real estate in a hemi engine compartment.I’m going to install the wix vapor separator filter soon. I found this photo on another thread. Any reason why I couldn’t flip that 90 degree brass elbow upside down so the rigid line has a straight shot up to the carb? Of course I would make it shorter since the return line still needs plumbed down and back towards the rear. I also have read some people running the flow through this filter backwards so the return port is on the bottom and have had no adverse issues.
Why didn’t I think of that earlier I just did that test and blowing into either inlet or outlet flows freely. Blowing into the outlet side didn’t feel any more difficult but maybe a slight less amount of air velocity existing the inlet port. I don’t think it will be an issue. I will see if Wix confirms.If youre going to try and mount it up-side down as in your picture, you could blow into it and exhale back to see if it would be like a check valve.
