- 1:10 AM
- Jun 19, 2016
- Beaver Dam, Wisconsin 53916
I have a set of 240 trick flow heads and purchased a set of
COMP Cams Rocker Arm Kit 1621-16; Ultra Pro Magnum 1.5 Roller for B/RB Mopar
Problem is either the rocker or the pedestals will have to be ground down to get proper valve alighnment,any one running a different set of rocker arms that only needs to be shimmed,dont want to grind into either of these,also these rocker arms are brand new if anyone is looking for a complete new set
