Mason
I've finally got an account to hopefully figure out my problem I've been trying to solve for the past few days, as of now electrically I've got both high/low beams working as well as parking lights, turn signals for the front, rear tail lights work, dash lights work, indicators work, hazards for the front work, windshield wipers work. My problem I'm having is the brake lights do not work, and the only turn signal I can barely even notice is the drivers side, its such a weak signal you have to have your face right in front of it to see it. I tried the passengers side and I don't see any signal. Now what I have replaced are the turn signal relays as well as the hazards, thinking of putting a new brake light switch in to see if it will make a difference but I've also heard of turn signal switches going out in these B bodies but I don't think that's the case. Also I do remember the turn signals being stronger in the rear before but cant remember if the passenger side was out, also i do not have light bulbs in the reverse tail light housing if that makes a difference. Any help or suggestion is appreciated! Just a teen trying to get my first car running
