Glenwood
- 3:45 PM
- Jun 19, 2015
- Kawartha Lakes, Ontario
Well I had the original sender fixed a few years ago but it hasn't been working consistently this year. Will go to full when I filler up but sort of drops off at 3/4 full to E but bobs up now and then while driving.
Couldn't find a replacement that is shaped the same but spectra specs the FG129A as the replacement so I ordered one.
Not even close in design but looked like it should still work. I bent the tube a little more to match the angle for the pickup and the float range seemed to match, so I installed it while jacking the front up to push the fuel in the tank back. Installed without issue and I now have a working gauge! Now I'll have monitor the range for accuracy so I dont run out of gas!
