Harmonic Balancer
Houle #382
1:01 AM
Hastings NY
Has anyone replaced their stock Harmonic Balancer with a good quality aftermarket one ? If anyone has what brand did you purchase and what brands should you stay away from.
It really depends on the engine build. For
a stock engine you could use a Mopar Performance replacement damper. 65'
340 stock block with ported X heads, ported Edelbrock performer RPM intake. Edelbrock 650 AVS-2, Pertronix ignition system. Stock exhaust manifolds automatic with 3:73 posi gears. Hughes Engine Cam kit 518 lift 224 duration
I used this one on a 408 (360 stroked)
https://www.summitracing.com/int/parts/pfs-80012/overview/
Includes 3 different counter weights and instructions to fit all small block Mopar engines.
