From my experience with quench. Used KB quench pistons, 906 heads, equalizing all the chamber depths, removing sharp edges in the chambers. .038"-.040" piston to head. Small [email protected] cam. Measured 9.7-1 compression. Stock intake, carb, exhaust, 3.23 gear 70 RT convertible. Will not run on 93 octane above 80 degrees ambient @36 degrees total. Was it worth the work to get quench? Nope.
