We had a machine at work that used a abrasive combined with high pressure water. It had a recovery system and was involved and required maintenance often. When it worked it did a good job. It was enclosed similar to any blasting cabinet. Without a containment system id think it would make a big mess.
But id still be interested to see a system that incorporated a pressure washer and how it performs
We had a 60 Pontiac Ventura done . The blasting work was real good. But the cleanup was just about the same as the normal sand blasting. Not much for warpage. But that depends on how good the person operating the equipment is .
They have some decent ones that attach to the end of your wand and siphon the abrasive up and out.
got to say, for very little investment they work pretty good!
