I am unaware of any way to rebuild these. I think they are too hard to get apart so that they can be reassembled. If you look for replacements, be aware 68 and 69 are slightly different. 68 has a magnet built in that can hold the headlight door open in case of a vacuum failure. 69 used a stamped steel rod bolted to the actuator tray and no magnet in the actuator. At the end of the day, it probably doesn't matter, just FYI.
