Consoles
Mango 1
9:11 AM
Nebraska
Looking to install a console in my 73 Charger. Has anyone installed one, aftermarket or other from a donor? Any pics would be great
I fabricated one for my 65 Coronet. Used 1/2" MDF board and the wife sewed up a cover for it.
Mike
The best case scenario would be one from a donor car where they cut the hump out and left the brackets welded on.
Installed a console from a Lincoln in my '63 Fury earlier this year. I had some decent gauge sheet metal to fabricate the brackets, rivet, drill, bolt, wire up, etc. The hump isn't dead center in the car so had to accept a slight offset but I read in a recent post just a few days ago this is common.
Console 1 pic Plymouth.jpg Ply Console Bld wiring.jpg Ply Console L.jpg Plymouth Console Setting.jpg
If you would like more photos I can send along. It was more work than I thought; but this leather console I got at a swap meet for 10 bucks some years ago has a light bar so I rewired for brake and turn signals, headlights. A buddy fabbed out the aluminum (scrap from his shop) for extra gauges and cup holders. Also had to make up a block underneath the box to level it out a bit and some drilling out for the wiring harness. Painted the leather (Herb's paint) that was dark maroon to mate with the interior red and worked out pretty well for a better match. Again a great thanks to those on our forum who had some great advice to help me complete this!
In my '72 SSP I used a factory console but replaced the faux wood grain overlay with a real slice of alder wood.
From scratch or replacing existing? I have pics of mine before interior went in on my 73.
Going from scratch, have removed the Slap Stick and installed B&M Star Shifter. Only thing in the way is the B&M shifter. Really want to put the Tach, gauges, and Heat / A/C controls in it as well.
Thanks,
Mango
Thanks guys for the pics and feedback on what you have done. I really appreciate all of you taking the time to post the pics giving me some ideas on what to do.
Thanks again!
Mango
This console fits very well in the 71-74 B-bodies.
Looks like the Cordoba! I had a '75 and an '80...got to like the '80 body style more as the years have gone by...
IMO use an original Slap Stik set-up and ditch the B&M Shifter. Your rallye cluster (if equipped) has the necessary gauges you need. IMO aftermarket gauges hanging down under the dash frame looks tacky.
Good luck on what ever direction you choose.
:thumbsup:
