SOLD 69 roadrunner parting
jdakrt
4:25 AM
Central VA
Feedback: 1 / 0 / 0
No motor no trans. Rust in rear framerails, trunkpan, floor and quarters. Shock crossmember is cracked.
Non roller metal shell- 1k, or 700 without fenders. Dash extra( yes I have the title)
No fender tag, build sheet is here but illegible.
Rot free fenders $500
68? Trunk lid -$150 has a little rust but nothing thru.
Bayonet style hurst shifter with rods and levers-$250
Big block 11” bellhousing- $400 - SOLD
Hood inserts - one stud broken, missing most of the speednuts.
8-3/4 open with 11” brakes
Door and rear card set
Cluster with clock
Map light
Switch panel with rear defrost
Nice rear seat, needs recover
3641BC88-68DD-43F5-9419-5385DCDBF145.jpeg 09D5D02E-304A-4324-A52A-35DA5C4039EB.jpeg 2A6D687D-B8CB-44D1-B09E-75340F0CA922.jpeg 4F9D0FBC-6257-4F31-96A3-90E459AB598D.jpeg 544092DC-1268-454E-9CAA-7249B1D507CA.jpeg 741E5F8D-3E15-425A-B1CE-947716259668.jpeg 741CA5AD-6F5A-4F3E-B5C0-BB9469D7131E.jpeg 28EE3294-3891-4218-9507-82C75EC5EB12.jpeg
I’m looking for the drivers side end of the torsion bar crossmember if it’s in good solid shape. From the torsion bar socket to the rocker, with the flanges that weld to the rocker intact.
I am interested in the horn ring with pad if it is for sale. Thank you.
D
Not looking to hack it up right now, just don't have the time. Metal shell can be bought for 1k, or 700 without fenders. Roller will be more. Horn ring is still available. Pm me. Yes, 4 speed. Pedals- 250 shipped. Will be complete with otc spring and hardware.
Speedometer cable?
I sent you a PM. Will need your address to get an accurate quote
Will you sell the clock or is it whole cluster? If so how much?
The pictured A pillar plastic trim...what are you asking?
Interested in everything for the rear defrost including the switch panel, wiring, and blower.
