68 RR Needs Elect Pusher Fan
I recently did an 22" radiator shroud brackets fan and clutch for a guy. I believe he got everything from Mancini but I did have to weld the brackets on, 4 small welds and it cools great in Phoenix
My radiator does not have provisions on the side to mount a fan shroud. If you know of a fan shroud and a mounting kit to attach it that will fit on my radiator please let me know because I have not been able to find anything yet. I could buy a whole new radiator and order it with a fan shroud I guess but I really would like to do something simpler. View attachment 848870 Thanks.
These say they fit your car.
http://www.megapartsusa.com/proddetail.asp?prod=101-FS7423
http://www.megapartsusa.com/proddetail.asp?prod=101-FS9555
I believe the clutch senses changes in air temperature and requires heat from the radiator to function properly........ without the shroud, the clutch thinks the radiator is cooler than it really is; therefore it wont engage
I wasn't trying to be rude about it, just in my opinion , popping the hood and seeing the electric fan right there in front would immediately take away from the stock look. I agree the clutch fan may be a problem with the 22" radiator. for comparison sake, I use a clutch fan , with a small block 2 core 26" radiator, a 180* thermostat and a shroud with my 440, and it never gets over 205* sitting still , in gear , for what seems like days in 95* weather. maybe you should look at the thermostat too, I always test them in boiling water before I put them in. I had 2 in a row that did not open right out of the box , and one that barely opened before I went and bought an expensive one that worked.
I just recently bought an aluminum 2 core 26" radiator because I like the look, and I don't even need the shroud and it doesn't exceed 200* no matter how hot it is outside or how long I run it.
I tested a brand new 180 deg thermostat before I installed it and it worked perfect. I'm convinced the problem is the smaller fan and the fan clutch combined with the lack of a shroud. I was hoping for a simple solution like adding an elect fan in front (I've seen it done sucessfully on other cars). Sorry if I seem frustrated with this issue. It's been a long road to get the car to this point and there's only a few last issues dogging me keeping me from driving the car. Besides that I'm getting to be a grouchy old bastard anyway ;))
Shroud is absolute necessary. Do the basics. Flush the system, change thermostat. Do you have the plate @ the bottom of the bumper going to the frame ? By the looks of your pics , air is going where it wants to and NOT through the rad ! I am not an advocate of electric fans, sometimes diverts air rather than directs it. Big rad with shroud should do it if you want to spend the $$$.
Thanks, I already flushed system, new thermostat (checked 180), new water pump, radiator completely flushed and cleaned, all basic systems in good working order. Yes I have the plate to seal off bottom of bumper air.
After giving careful thought to everyone's advice, I'm thinking about just ordering the fan shroud and mounting kit (almost $500) and see if that does the trick. But considering price maybe I should just buy a new radiator with shroud. Still thinking.
What company would be best of buying a new radiator with matching shroud together?
From the Govier book, I see
2949035 listed as a 22", 69 C-body, 383/440. For a B-body, 22", I see
2949053, also 383/440. I don't know what the difference could be
Ima thinking a 22"rad was borderline for stock 383 application, with no shroud.
Check your vacuum advance operation. Below 30 mph, and with an automatic, the Rs are gonna be very low, and that means the Fanspeed is also gonna be very low. If the timing isn't up where it should be, then the mixture may not all finish burning in the chamber. That means the exhaust will be hotter and as it passes thru the exhaust port, it will heat the cooling system up as well.
Because of the low-rpm and no shroud;that 5blade fan is not gonna be enough for that 22" rad.
There is nothing wrong with running a clutch fan EXCEPT it has to be a THERMOSTATICALLY controlled one,; NOT viscous only, and the cooling system temperature has to get hot enough to turn the dang thing on.And the waterpump has to be moving the water.
Here's what I know works, cuz it took me a whole summer to get it sorted out; But it's a system. I cannot guarantee it will work for you if you don't use the whole list.
1) a 7 blade all-steel, vortex-tip , factory fan
2) a T-clutch off an early 2000s FORD Pick-up truck
3) a HD Hi-Flo waterpump with an anti-cavitation plate. (This has a bigger shaft to support that heavy 7-blade fan)
4) A hi Flo 180 or higher thermostat. (I use a 195)
5) An anti-collapse spring in the lower rad hose
6) a restricted bypass hose to stop most of the water from going back into the pump for a second go-around; use the heater as a bypass.
7) make sure the WP pulley diameter is NOT bigger than the crank pulley.
8) make sure the belt doesn't slip when the clutch kicks in
9) crank up the idle timing, speed up the mechanical advance curve, and modify your V-can for more and earlier advance. How much? As much as she'll take until she detonates and then back-up 2-3 degrees.
10) make sure the tubes in the rad are well able to flow water. and that the fins are properly attached and directed, and not plugged with debris.
11) make sure the coolant freeze-protection is not excessively high, anti-freeze is a lousy coolant. Pure water is nearly the best.
12) run a coolant expansion tank/recovery system.
13)make sure all the air hitting your rad is forced to go thru it, and not sneakind around,over or under it
14) reserved for in case I remember something else,lol
15) if you do all of the above, then any POS rad will work, and possibly without a shroud as well.
16) don't be thinking that 7-blade will suck all your power.
That clutch will only be needed at idle to perhaps 30 mph.
After 30 mph, Ram-Air will try to cool your engine to below the 180stat, but that hi flow stat won't let it go any cooler The fan-clutch may not engage until 205*, and until then,it is gonna be freewheeling costing you almost nothing. The faster you go, the more the coolant will try to go less than the stat, and the harder it will become to overheat her. If you get the speed up to IDK, say 120mph, now the engine is gonna be working hard, the coolant temp will rise, the stat will open and that bad-boy pump is gonna start earning it's keep. The clutch may engage, but IDK, probably not. I have never heard mine above 30mph,ever.
As to ignition timing;
Idle timing;
with a manual trans ;14 to 18 depending mostly on your cylinder pressure and altitude.
With an automatic 16 to 22, depending mostly on your stall, and as above.
Power-timing;
32 to 38, depending on the gas you use and the chamber design/material
Timing curve;
Idle-timing stable to idlespeed plus ~200rpm, then begins advancing; All-in by 2800 to 3600, depending on detonation onset.
V-can timing;
stockers are slow and anemic, sometimes as little as 9*
Your slow-cruise timing can be as high as 52* at 2200 rpm; that is all-together.
example;
Let's say you have 3.23s, and cruising at 22 mph;
in Drive, the Rs might be as low as ~900rpm, and the timing will be just the base timing, cuz the mechanical doesn't start advancing until 1000 rpm, and the V-can needs more throttle-opening to get going. So IIRC, the factory timing was maybe 5*, which is gonna be hopelessly retarded. Even 16* is not enough. So don't cruise at 2200 in Drive with 3.23s; put it in second.
In second 22mph might be ~1300rpm. Now your timing might be base 16* plus say 1* per 100rpm beginning at 1000=3*, plus the Vcan may be on line with 50% of it's available timing=4.5*; for a total of 16+3+4.5=23.5.... which is still not enough, but waaaaaay better than 5*,lol. I would modify the stops on the Vcan and crank it up to maybe 18*. At 50% this will get you another 4.5* for a total now of 28*, still not enough, but about as good as it gets.
How do you know when the cruise-timing is enough?
Easy; put a timing lite on it, crank the idle speed up to say 2200, then with the Vcan plumbed to the spark-port, begin adding timing. Start at 35*, and reset the speed back to 2200; then add 5* and reset the rpm. Repeat until the rpm no longer rises, then go back to the previous setting. The timing that you are at now is what she likes at 2200 with no-load. I bet you get more than 40*, maybe more than 50*, maybe as high as 55*!
Ok but that was with no load.
What about while driving? It really depends on the load,the AFR, and the stall.
The higher your gears are (smaller numbers), the larger will be the load on the engine, and vice-versa, the bigger the gear number is, like 4.30s, the easier will be the load on the engine.
The less the load, the more the timing can approach the optimum; and the greater the load, the less timing the engine will tolerate.
Some guys are able to run 42*@2200 cruising, some run 48*, and some like myself have run 52*@2200.... or more....... IIRC, TrailBeast on FABO runs similar numbers, maybe a tad more.
I had 2
Could the new clutch be faulty?
I had 2 fan clutches that where bad out of the box, they where hd units for an rv. a shroud is supposed to be there. you don't have diddly flowin thru your core, or your core could be clogged up, an need to be rodded out. at any rate you need good airflow at low speed. your rr is identical to the one I purchased in 1968, I spent 714 bucks more for the hemi. paper thin carpet an a taxi cab bench seat.
Long story short, I changed to a clutch fan on my 68 Road Runner (383) and now it starts to overheat if I idle around too much. I know I could try to get a fan shroud that fits and maybe a bigger radiator, etc. But I like the way it looks under the hood now and don’t want to change it.
I just want to add a thermostatically controlled electric fan in ‘front’ of the radiator. That should more than take care of the heating problem and allow me to keep the stock looking engine bay (in back of the radiator support). But I noticed the radiator fins (in front) are in set back from the radiator core support about 2.5 inches. So I’m not sure which elect fan I can buy that can mount in front of the radiator and yet set back a couple inches to be closer to the radiator fins.
Has anybody encountered this before and do you know if they make electric fans for ‘in set’ mounting to the front of the radiator? Which manufacture is best? As always, huge thanks for any help and advice. RRDon
i thought same but look real hard at fan shrouds. I emailed Tony’s Mopar and he refereed me to Dantes Mopar Parts. I bought fan shroud and side brackets. The little clips on side just popped in and whole job done in under and hour. I did have to pull and reinstall fan blade. Overall still clean, clutterless, safer and cooler. They offer two so measure radiator. The push fan really takes away the factory look in my opinion
Turns out the mounting brackets & clips I ordered will not work on my radiator. Apparently no products available to attach a shroud to this particular radiator. I'm just going to buy a new direct fit radiator from Cold-Case complete with shroud and fan. They now make them with OEM style tanks to maintain that close to original look.
Also I want to thank everybody who contributed to this thread. I know some of you guys spent some considerable effort to provide useful information. Thanks again. RRDon
Cold Case Radiator kit Ordered from Summit. Will paint it black before installation.
