Wtf is this?
I've been rebuilding TFs for close to 50 years now and never needed to replace the extension housing bushing in the car. If it wasn't bad on the bench it will out last the trans rebuild and can be done the next time. Don't put the drive shaft yoke in dry (like some other things)!
Mike
Ran a driveshaft that was to short, a screw up.
Well now that Fran posted the part number I won't have to remove the tail housing.:p
Gotta make sure the oil hole is in the proper position when you drive the new one in, too. :)
Here's a better deal than mine, check details say 727 but check. not mine.https://www.ebay.com/i/254104262633...MI_K7ytdik5QIVlIzICh1qeQuSEAQYAiABEgLpQPD_BwE
Thanks to fellow member @Beekeeper , I can attest the Miller tool is amazingly easy to use and works like a champ. :thumbsup:
Yes, the bushings DO wear out:
