Hood release will not release good catch and banging on the hood to get it to loosen up and jump up enough to put your fingers under it doesn't work. Any ideas how I should go about getting this thing open?
I put something under front of hood to give it some tension to pop up when you pull the hood release cable. Alot of times the hood bumpers need to be adjusted up after being squashed down for years.
Good idea I'll try it thanksI put something under front of hood to give it some tension to pop up when you pull the hood release cable. Alot of times the hood bumpers need to be adjusted up after being squashed down for years.
