diemaker
Hi Guys,
I need to remove the dash/ cluster in my 64 polara. I have looked through the service manual from Chrysler and there is nothing on there about this. Can anyone point me in the direction of some instructions for doing this?
I need to see what Is going on with the temp gauge not reads very high and well driving is pinned to the right side even cold it shows 3/4 of the way all the other gauges and lights work fine and I verified that the motor is not that hot. I also replaced the sending unit and didn't t-tape the threads the gauge does go to the far left when the car is turned off. wonder if its out of calibration? I also need to remove my heater push button as 3 of the nipples are broken off the back.
