rich hourigan
hey guys , im restoring my 67 X and am in need of some plug wires..... can someone recommend a vendor that sells the chrysler reproduction wires ... as always thank you ...Rich
Depends on what type of electronic you are using. My Hemi has a stock original dual point dizzy that is converted to Pertroxyx ignition. Looks bone stock. I got my wires off eBay as the seller had the date codes I needed. And number 7 wire had a rubber extension on it making it pretty easy to get in with the brake booster in the way. Username was Lectralimited.ive been looking around at year one reproduction wires... the description says for points type ignition. i will be useing electronic ignition, does someone make a reproduction wire kit for my application. im trying to stay stock looking under the hood ... i like the look of the reproduction kit with the pentastar logo and the date stamped on them ...Rich
....just remember to use a bit of lube when dropping them on the plugs....has a few of mine get stuck on there...and pulled off the boots. Lectric replaced them at no chage....hey guys, thank you for the responses.... i just ordered a set from Lectric ... super nice people took my order.... thanks again
My dad bought his from Classic ind. The are date coded & the right color. Plus they are for a duel point ignitionhey guys , im restoring my 67 X and am in need of some plug wires..... can someone recommend a vendor that sells the chrysler reproduction wires ... as always thank you ...Rich
