1970 Roadrunner water pump
DWoody
3:52 PM
Mableton, GA
Took the water pump off a 440 and did not pay attention to the arrow and weep hole location. Does it go on with the arrow up and hole down?
2019-11-23 13.06.17.jpg 2019-11-23 13.06.01.jpg View attachment 870345
When I was posting these photos, I did take a photo before taking it off, so I can see the hole goes down, thank you!
Got the new water pump on and changing out the radiator and fuel pump.
Days gots arrows on em now?? :D Nice looking 70 coupe!
Installed water pump, fuel pump and radiator. Moved electric fan to new radiator and repaired it's electrical connections. When removing the fuel pump, something fell and hit the frame, like my socket fell off. It was one of the spacer/sleeves that goes over the alternator bolt, so I was able to replace the 3 nuts and 2 washers that were used when it was lost to hold the alternator aligned.
2019-11-24 11.49.18e.jpg 2019-11-26 16.01.11.jpg 2019-11-26 16.01.00.jpg 2019-11-26 16.00.45.jpg 2019-11-26 16.00.40.jpg
In this photo, you can see just one of the nuts and the 2 washers that was around the alternator bolt.
