- 7:46 PM
- Mar 28, 2014
- South Louisiana
It was suggested that I replace my factory hard brake lines with new stainless steel hard lines. I believe that I'm getting what I need to match up the factory brake lines with the Wilwood brakes within these parts??
Front:
15" Front Flex Lines AN-3 Size
Hard line conversion fittings in 3/8IF and 7/16IF
Male/Male AN-3 to 1/8" NPT for calipers
Rear:
15" Drop line AN-3
3/8 IF and 7/16 IF hard line conversion fittings
Simple AN-3 T Fitting
(2) 30" AN-3 lines to span the rear end
So I'm guessing that I should just buy a complete line set to replace my factory lines, and the Wilwood parts in red will match everything together?
Front:
Rear:
15" Drop line AN-3
