FOR SALE Rebuilt 8 3/4 Sure Grip - Moser
Flys-Lo
10:52 AM
Akron, Ohio
489 Housing
7290 Fine Spline Yoke.
Never been installed, never run. Brand new.
Ready to install and go.
New Kit Including:
Nut, Bearings, Races, Shims, Seal,
Ratech Spacer
3.55 Ring And Pinion
Parts & Set Up by Moser Engineering.
$850
Located in Akron, Ohio.
Shipping extra. (from 44216, Akron Ohio)
Credit cards accepted - add 3%
39917075_10213179241101368_3158849112204378112_n.jpg 39878762_10213179242381400_2190534570519035904_n.jpg 39983944_10213179242181395_2050802817475543040_n.jpg 39891301_10213179241901388_6083054531711598592_n.jpg 39951629_10213179241661382_2529485572678877184_n.jpg 39950174_10213179241181370_7654030912912359424_n.jpg
Is that a small yoke
Yes. As long as you have an 8 3/4 housing you just pull your axles out about 10”, swap your unit for the sure grip and reinstall. There’s a bit of adjustment, etc but to answer your question, stock axles work fine.
Would this work with a stock axle?
