63-65 Plymouth Interiors/Seat Interchangability
Wizard
12:44 PM
Dillsburg, PA
I have a 63 ply Belvedere 2 door post car. I also have a 65 Ply Belvedere II 4 door which has a bench and rear seats. Are the bench seats and rear seats the correct seats/same for the 63 ply Belvedere? I need the interior for the 63.
Also, I have a 64 Fury convertible and a 64 sport fury convertible and 64 hardtop. Would any of the 65 belvedere interior work for any of these cars be correct? The bench seat and rear seats?
Basically, what can I rob from the 65 Ply Belvedere II that will swap in stock and be correct for any of the 3 cars I have?
Back seat should fit'front seat will not fold forward to let folks in, don’t think it will fit in the holes in the floor
Is the front seat the same width as a 2 door bench seat? Can the 4 door bench be modified or is it just to wide to fit in the 2 door 63 to even work correctly?
Two doors have a split seat back most four door have a solid back,if your short drill new holes in the floor than slide the seatforward
The 4 door back seat bottom has curved ends for ease of getting in. The 64's will have more square seat ends on the bottom cushion because of the 2 door.
Yes, my 4 door has a solid bench. Are u saying the 2 doors have a split front bench or are u talking about the rear seats have a split seat?
The seat back on a two door,where your back goes is split,so when somebody wants in the back you lifts lever and it flops forewords allowing you to enter the backseat
Front seats split and seat back swings forward to allow people to get in back seat unlike necessary on a 4 door..
And a 63 post car has the 60/40 split front bench. kind of rare these days. I saw the 63 front and rear set on Farcebook but the guy wants $650.
Okay, so the front bench out of the 4 door is a definite no go for putting in my 63 Belvedere or 64 fury hardtop for correctness to stock? The rear seats could go in either car but still not 100% factory correct?
Not sure on what you have for rear seats but the front on a 63 post car is definitely the 60/40 split bench. If youre after correctness this is the seat for your 63.
Here is whats in my 65 ply Belvedere II 4 door car that I want to try to use in either the 63 Belvedere or the 64 Fury 2 door hardtop. Anything factory correct for a swap?
View attachment 888661 View attachment 888662
Like others have said. You c
Like others have said. The four door seat bottom is different than a two door, so it wouldn't be correct for a two door if its out of a four door.
If you have a spare 650 laying around and don't mind a road trip to Oklahoma there's a guy on Facebook who has everything that you need......lol.
Right, appreciate it. guess all the seats in the 4 door are up for sale then. Parting the 4 door out or sell whole
Geez 650! I trashed my bench when I put buckets in my '63. Go figure, I save **** that ain't worth **** then garbage stuff that is...
Yeah, it’s high but that 60/40 front bench is a sought after piece.
