FOUND 1970 Lower Control Arms with Sway Bar Tabs
Bschultz
11:08 PM
Carthage, MO
I'm looking for a clean set of LCA's with sway bar tabs. Surface rust is fine, I will sandblast and rebuild.
Thanks,
Brian
I think I have a set but they are off of a 69 roadrunner. Not sure if they are the same.
70 lower control arm tabs are not in the same place.
1969
1970
I believe you can buy the tabs and weld them on
I have a real nice clean used set, and also have the front sway bar, PM me if you still need them
