RobsRR
I have a numbers matching 383 71 road Runner. Have had it for 30 years. 10 years ago I rebuilt it. It is not used much still runs good. It is 40 over, block was zero decked, I put on Stealth heads they are supposed to be 80 CC. Compression ratio is 9.38 Static. Cylinder compression is between 150 to 160. Pistons are hypereutectic 5cc valve reliefs. Factory intake and a holly 3310 750cfm dual feed vacuum secondaries. Comp cam is hydraulic .475 lift duration at 50 is 233 and 240. (Nostalia Plus Cam). 1 7/8 headers. 3.55 rear. 10 inch turbo action converter I think it is a 3800 stall. Looking back I think the stall is to big. Street car.
Thinking of trying to get more compression if it would help? I would like a snappier throttle response and more low end and hp. I think the low vacuum 12 is causing poor velocity.
I understand the heads can be milled up to 060 safely. Not sure about piston to valve clearance if milled? Not sure where my compression would end up? I also have a edlebrook rpm sitting on the shelf that will replace the factory intake. Does it make sense to mill the heads will I notice a difference or do I just put on the new intake. The intake will have to be milled to fit regardless.(Block Decked.)
Thanks for any input.
