Stonehengeheel
Why don't your pictures match your description? It is in a boneyard. Why is one hood filled with rust and the other is not?
Those are 2 different people...Why don't your pictures match your description? It is in a boneyard. Why is one hood filled with rust and the other is not?
Yeh, what Kern said. Bad Karma taking advantage of widows, old folks or kids.
That looks like an easy fix and being a 383 4spd car it would be worth the effort if the rust is as you described and the trim looks good as well. I would have no problems going $4k not running if that helped her out and made her whole maybe a bit higher seeing it in person. Just make sure she has a good title to go with it so you have no trouble there.
Current Values as provided from Hagerty website (you have a ways to go to get to the fair #4 value below)
- #1 Concours $36,900
- #2 Excellent $26,500
- #3 Good $18,800
- #4 Fair $13,100
Thanks for all you guys help & advise. Makes it easier about the decision. I was actually, before all your input, that the car was a $1-$2 grand topsYeh, what Kern said. Bad Karma taking advantage of widows, old folks or kids.
- #3 Good $18,800
- #4 Fair $13,100
looks like it's got the low-perf exhaust manifolds.
I’m in agreement with you. Based upon the condition, I think it’ll take me about 4-5 grand to get it where it’s driveable but no bodywork or interior work being done to it. So I’d have 8 into it. I don’t know how much it cost to have the seats recovered and new carpet. The body I’m actually thinking I’ll just sand the rust smooth, patch the fe’s small holes and then clear the whole thing so you’d see the imperfections. Your thoughts?First thing would comes to my mind is why part out a factory 383 4 speed charger?
Second thing is that is worth 4-5k easily if the unibody and common problem areas are solid.. If you want to undercut her on the price then just lump yourself in with the thousands of other jerks trying make a buck off others because they lack knowledge on a certain subject.
It was her late husbands car she probably will feel he is taking care of her if she gets a fair number for it, and you get a factory 4 speed car. Also have to consider the rarity factor here..even at 5k its not all abou the money, its also about the time and or/your luck of finding a rare 4 speed example. If you like stick cars then they are far between and so all things considered it is a better deal, even though the price may not nessecarily be cheap.
There’s rust holes on trunk lid, passenger door and top of rear quarter panel. The metal around the rear glass is rusty real bad to the point I think it would take a donor car cut out of that and weld onto this car. That’s not easy to find or cheap to install.I think they all had those manifolds in '66, for the 4 bbl 383's. The car is a keeper, for sure. Trunklid looks like it will need metal to fix, check the back edge by the skin welds. Very hard to find a good replacement.
