New car help with a traction code
Bb70charger500
9:24 PM
fl.
Hey guys I got this 2007 srt8 super bee the other day and it has an esp and a bas light on !
My code reader can't read it but I went to a shop I used to work at and they gave me a new high dollar reader . It said
U0125 Lost Communication With Multi-Axis Acceleration Sensor (MAS) Module
What is this where is it I looked online but no one says where it is or what it is I saw a picture of a sensor but no other info not even sure if that's the sensor. Anyone know about this ? I'd really like to get the car 100% before I put the baby seat in the back !
Got this from a charger forum...
I have U0125 as Lost Communications with Dynamics Sensor...
When Monitored: With the ignition on.
Set Condition: If the Anti-Lock Brakes Module fails to receive bus messages from the Dynamics Sensor.
The Dynamics sensor is under the console between the seats. Check the sensor and make sure its oriented correctly. I think the arrow is supposed to face the rear of the car. Also clean the connectors and check for corrosion.
Its a black box with an arrow. I found a picture of it but lost that link.. Its basically a stability computer. It checks for acceleration,Yaw and roll.. Kind of like a Gyro for your car.
Thanks I'll take a peak .
If anyone has a picture I'll take it
Should look something like this.
Apparently directly related to ABS controller...
Here is a list of ABS codes.
AntiLock Brake Module
B1783-01-STOP LAMP CONTROL - GENERAL ELECTRICAL FAILURE
C0020-01-ABS PUMP MOTOR CONTROL - GENERAL ELECTRICAL FAILURE
C0020-16-ABS PUMP MOTOR CONTROL - CIRCUIT VOLTAGE BELOW THRESHOLD
C0020-1C-ABS PUMP MOTOR CONTROL - CIRCUIT VOLTAGE OUT OF RANGE
C0020-35-ABS PUMP MOTOR CONTROL - SIGNAL HIGH TIME>MAXIMUM
C0021-02-BRAKE BOOSTER - GENERAL SIGNAL FAILURE
C0030-02-LEFT FRONT TONE WHEEL - GENERAL SIGNAL FAILURE
C0031-1D-LEFT FRONT WHEEL SPEED SENSOR - CIRCUIT CURRENT OUT OF RANGE
C0031-2F-LEFT FRONT WHEEL SPEED SENSOR - SIGNAL ERRATIC
C0031-4A-LEFT FRONT WHEEL SPEED SENSOR - INCORRECT COMPONENT INSTALLED
C0031-62-LEFT FRONT WHEEL SPEED SENSOR - SIGNAL COMPARE FAILURE
C0033-02-RIGHT FRONT TONE WHEEL - GENERAL SIGNAL FAILURE
C0034-1D-RIGHT FRONT WHEEL SPEED SENSOR - CIRCUIT CURRENT OUT OF RANGE
C0034-2F-RIGHT FRONT WHEEL SPEED SENSOR - SIGNAL ERRATIC
C0034-4A-RIGHT FRONT WHEEL SPEED SENSOR - INCORRECT COMPONENT INSTALLED
C0034-62-RIGHT FRONT WHEEL SPEED SENSOR - SIGNAL COMPARE FAILURE
C0036-02-LEFT REAR TONE WHEEL - GENERAL SIGNAL FAILURE
C0037-1D-LEFT REAR WHEEL SPEED SENSOR - CIRCUIT CURRENT OUT OF RANGE
C0037-2F-LEFT REAR WHEEL SPEED SENSOR - SIGNAL ERRATIC
C0037-4A-LEFT REAR WHEEL SPEED SENSOR - INCORRECT COMPONENT INSTALLED
C0037-62-LEFT REAR WHEEL SPEED SENSOR - SIGNAL COMPARE FAILURE
C0039-02-RIGHT REAR TONE WHEEL - GENERAL SIGNAL FAILURE
C003A-1D-RIGHT REAR WHEEL SPEED SENSOR - CIRCUIT CURRENT OUT OF RANGE
C003A-2F-RIGHT REAR WHEEL SPEED SENSOR - SIGNAL ERRATIC
C003A-4A-RIGHT REAR WHEEL SPEED SENSOR - INCORRECT COMPONENT INSTALLED
C003A-62-RIGHT REAR WHEEL SPEED SENSOR - SIGNAL COMPARE FAILURE
C0042-11-BRAKE PEDAL POSITION SENSOR - CIRCUIT SHORT TO GROUND
C0042-12-BRAKE PEDAL POSITION SENSOR - CIRCUIT SHORT TO BATTERY
C0042-28-BRAKE PEDAL POSITION SENSOR - SIGNAL BIAS LEVEL OUT OF RANGE / ZERO ADJUSTMENT FAILURE
C0042-2A-BRAKE PEDAL POSITION SENSOR - STUCK
C0042-54-BRAKE PEDAL POSITION SENSOR - MISSING CALIBRATION
C0042-62-BRAKE PEDAL POSITION SENSOR - SIGNAL COMPARE FAILURE
C0044-01-BRAKE PRESSURE SENSOR 1 - GENERAL ELECTRICAL FAILURE
C0044-28-BRAKE PRESSURE SENSOR 1 - SIGNAL BIAS LEVEL OUT OF RANGE / ZERO ADJUSTMENT FAILURE
C0044-49-BRAKE PRESSURE 1 - INTERNAL ELECTRONIC FAILURE
C0044-62-BRAKE PRESSURE SENSOR 1 - SIGNAL COMPARE FAILURE
C0051-22-STEERING WHEEL POSITION SENSOR - SIGNAL AMPLITUDE > MAXIMUM
C0051-28-STEERING WHEEL POSITION SENSOR - SIGNAL BIAS LEVEL OUT OF RANGE / ZERO ADJUSTMENT FAILURE
C0051-49-STEERING WHEEL POSITION SENSOR - INTERNAL ELECTRONIC FAILURE
C0051-62-STEERING WHEEL POSITION SENSOR - SIGNAL COMPARE FAILURE
C006A-28-MULTI-AXIS ACCELERATION SENSOR - SIGNAL BIAS LEVEL OUT OF RANGE / ZERO ADJUSTMENT FAILURE
C006A-49-MULTI-AXIS ACCELERATION SENSOR - INTERNAL ELECTRONIC FAILURE
C006A-56-MULTI-AXIS ACCELERATION SENSOR- INVALID / INCOMPATIBLE CONFIGURATION
C006A-62-MULTI-AXIS ACCELERATION SENSOR - SIGNAL COMPARE FAILURE
C0078-86-TIRE DIAMETER - SIGNAL INVALID
C1046-92-LEFT FRONT WHEEL PRESSURE PHASE MONITORING - PERFORMANCE OR INCORRECT OPERATION
C1047-92-RIGHT FRONT WHEEL PRESSURE PHASE MONITORING - PERFORMANCE OR INCORRECT OPERATION
C1048-92-LEFT REAR WHEEL PRESSURE PHASE MONITORING - PERFORMANCE OR INCORRECT OPERATION
C1049-92-RIGHT REAR WHEEL PRESSURE PHASE MONITORING - PERFORMANCE OR INCORRECT OPERATION
C1082-01-VACUUM PRESSURE SENSOR - GENERAL ELECTRICAL FAILURE
C1082-02-VACUUM PRESSURE SENSOR - GENERAL SIGNAL FAILURE
C1082-2F-VACUUM PRESSURE SENSOR - SIGNAL ERRATIC
C121A-09-STEERING ANGLE SENSOR NOT INITIALIZED - COMPONENT FAILURES
C121C-00-TORQUE REQUEST SIGNAL DENIED
C1239-00-EMISSION ROLLS TEST ACTIVE
C123B-4B-ESP SYSTEM CONTROL TOO LONG - OVER TEMPERATURE
C1246-1C-VACUUM PRESSURE SENSOR SUPPLY - CIRCUIT VOLTAGE OUT OF RANGE
C124F-00-ESP REQUEST DENIED FROM ACC
C1252-92-VACUUM PUMP CONTROL CIRCUIT - PERFORMANCE OR INCORRECT OPERATION
C2100-16-BATTERY VOLTAGE LOW - CIRCUIT VOLTAGE BELOW THRESHOLD
C2101-17-BATTERY VOLTAGE HIGH - CIRCUIT VOLTAGE ABOVE THRESHOLD
C2114-16-DYNAMICS SENSOR SUPPLY VOLTAGE - CIRCUIT VOLTAGE BELOW THRESHOLD
C2114-17-DYNAMICS SENSOR SUPPLY VOLTAGE - CIRCUIT VOLTAGE ABOVE THRESHOLD
C211B-92-IGNITION RUN/START INPUT CIRCUIT - PERFORMANCE OR INCORRECT OPERATION
C212A-16-SYSTEM VOLTAGE LOW - CIRCUIT VOLTAGE BELOW THRESHOLD
C212A-17-SYSTEM VOLTAGE HIGH - CIRCUIT VOLTAGE ABOVE THRESHOLD
C2200-41-ANTI-LOCK BRAKE MODULE INTERNAL - GENERAL CHECKSUM FAILURE
C2200-44-ANTI-LOCK BRAKE MODULE INTERNAL - DATA MEMORY FAILURE
C2200-45-ANTI-LOCK BRAKE MODULE INTERNAL - PROGRAM MEMORY FAILURE
C2200-46-ANTI-LOCK BRAKE MODULE INTERNAL - CALIBRATION / PARAMETER MEMORY FAILURE
C2200-47-ANTI-LOCK BRAKE MODULE INTERNAL - WATCHDOG / SAFTEY AuC FAILURE
C2200-48-ANTI-LOCK BRAKE MODULE INTERNAL - SUPERVISION SOFTWARE FAILURE
C2200-49-ANTI-LOCK BRAKE MODULE INTERNAL - INTERNAL ELECTRONIC FAILURE
C2202-00-ORIGINAL VIN MISMATCH / MISSING
C2206-00-VEHICLE CONFIGURATION MISMATCH
C220B-00-ABS ACC NOT CALIBRATED
U0002-88 CAN C BUS OFF PERFORMANCE-BUS OFF
U0100-00-LOST COMMUNICATION WITH ECM/PCM
U0101-00-LOST COMMUNICATION WITH TCM
U0104-00- LOST COMMUNICATION WITH CRUISE CONTROL MODULE
U0125-00-LOST COMMUNICATION WITH DYNAMICS SENSOR
U0126-00-LOST COMMUNICATION WITH STEERING ANGLE SENSOR
U0140-00-LOST COMMUNICATION WITH BODY CONTROL MODULE
U0401-00-IMPLAUSIBLE DATA RECEIVED FROM ECM/PCM
U0402-00-IMPLAUSIBLE DATA RECEIVED FROM TCM
U0405-00-INVALID DATA RECEIVED CRUISE CONTROL MODULE
U0422-00-IMPLAUSIBLE DATA RECEIVED FROM BODY CONTROL MODULE
U0429-00-IMPLAUSIBLE DATA RECEIVED FROM SCM
U0432-00-INVALID DATA RECEIVED FROM MULTI-AXIS ACCELERATION SENSOR MODULE
U1003-88-ESP CAN C BUS PERFORMANCE-BUS OFF
U140E-00-IMPLAUSIBLE VEHICLE CONFIGURATION DATA RECEIVED
I found this on bay
But the numbers don't work on rock auto or AutoZone
Ok parts out and no one knows what it is all parts stores say no such thing what is the actual name for this most are saying stability control module .
Auto zone and o Riley says no such thing!!!
Why don't you go to the dealer? Not everything cost $10M...
Check the wiring, connectors/contacts, and contacts on the MAS before you buy a new MAS.
I found e bay onesb I want new .
It's definitely bad it was leaking goo and has a burnt smell. I'm afraid to buy used asm has only 69000 miles on car .... but I think I just found one at dealer they want $800 for it!
So used it might be !
WEll at that price you can afford to buy 6 ebay ones and one of them have to be good. My diagnostic fee is 1 million bucks..
I'm noticing it doesn't do much of anything . Besides if you go sideways it takes power away ! I might just leave it unplugged
Its basically stability control. As they used to say from the wheel that slips to the wheel that grips. I dont think you will like not having that in the rain.
Internet quote here..
Electronic stability control (ESC), also referred to as electronic stability program (ESP) or dynamic stability control (DSC), is a computerized technology[1][2] that improves a vehicle's stability by detecting and reducing loss of traction (skidding).[3] When ESC detects loss of steering control, it automatically applies the brakes to help "steer" the vehicle where the driver intends to go. Braking is automatically applied to wheels individually, such as the outer front wheel to counter oversteer, or the inner rear wheel to counter understeer. Some ESC systems also reduce engine power until control is regained. ESC does not improve a vehicle's cornering performance; instead, it helps to minimize the loss of control.
According to the U.S. National Highway Traffic Safety Administration and the Insurance Institute for Highway Safety in 2004 and 2006 respectively, one-third of fatal accidents could be prevented by the use of the technology.[4][5] ESC has been mandatory in new cars in Canada, the US, and the European Union since 2011, 2012, and 2014, respectively.
Just went through this last week with my 07 super bee after I had the car towed and removed power from the battery it set the ESP light on. Have a friend that works at the local Chrysler dealer and said it can be reset by turning the steering wheel full left then full right. Also try the esp button on the dash to see if it resets.
