Robert Schaad
For those that do not believe any thing I say, I spent 20 years in Germany and always drove MOPAR. So I ran into many problems that I had to fix because there are no NAPA, or other parts stores there. You must fix it yourself. 1976 Aspen R/T, with a trans leak. The leak only happened when driven, not at an idle. WHY? What is it. One day on the Autobahn, my trans stopped working leaving a huge puddle of trans fluid on the ground. I added several quarts since we always carry extra in Germany. Got home, Then NO leak. No leak for several days.
So the answer is strange. I replaced my transmission, since I had another one. Upon close look, I found a hair line crack in the Torque converter snout. So the leak was caused by the high RPM driving, which would cause the crack to open a little, or the heat of the autobahn driving to open the crack a little. I have run into some very strange problems while serving in the Army in Germany.
