Steering knuckle
Mattias
7:09 AM
Sweden
Am I having the right type of knuckles?
When I read the Disc-o-tech it says the ”right” type of knuckles have a height of 4-9/16. It’s a little bit difficult to measure but I get mine to be 4-7/8. Do I have the -73 and up b-body knuckles?
They are the later style like FMJ. used them many times without issue. Actually Makes the car easier to align afterward. Done many alignments with them as well. Read here https://www.cartechbooks.com/techtips/knuckleinterchange/
Thanks for input!
So, you mean I should use the knuckles that I have? The disc-o-tech article is stating, with exclamation mark, that these should not be used.
However, I would be happy if they could be used with good result...
It is a controversial subject, but there are many cars running the taller knuckles. Do your own research and be happy!
Thanks for input!
The man that wrote the "Disc-O-Tech" article is a smart man but he was just plain wrong in his condemnation of the later model steering knuckles. His contention was that the taller knuckle would result in excessive angles of the upper ball joint leading to failure. THis has been proven wrong by many other sources.
I agree
He also was not correct in his conclusions on how to deal with the early B-Body front anti-sway bars
There are correct and easy ways to rear mount the calipers and retain the stock sway bars
Using FMJ calipers that were designed to be rear mounted is one Banjo fittings can be another
Thanks for your answers!
I guess I will save some money and use the knuckles that I have...
/M
As stated above, used plenty of the tall spindles for conversions. My back ground? I was a suspension tech for over 30 years. Probably done 5000+ alignments. Plenty of repeat business. Never had an issue. The "over center" concern is from someone who never looked at the actual amount of travel. Same with the geometry. There's nothing critical there either. I'm sure you seen plenty of cars in a wheel stand with the wheels all angled in at the top. Take a look at the two pictures. One car has tall knuckles, one doesn't. Can you tell which is which? The camber curve looks good in compression as well.
Thanks Doug!
I understand that you are sitting on quite a lot of experience from this matter...
Do you have any suggestion if I decide to go the ”dropped spindle” way? Are there different manufacturers with different quality and/or steering geometry?
I've never used one. However if just the spindle itself is dropped the geometry shouldn't change.
