bhemi
I have a 1974 Satellite Sebring Plus. It has a an 8 1/4 open in it now. 400 engine and a Torqueflite. This weekend I picked up an 8 3/4 housing from a '71 Charger with a 489 case, it has 2.73 gear and is an open. It came apart but with the factory axles.
I want a limited slip like a Truetrac as the goal is to do a stroker kit on the 400 eventually. Say 500 hp max and street driven. Advice on gears and LSD would be appreciated. I am assuming the housing is a straight swap. New axles? Which bearings?
