DartGTDan
My buddy's '63 Dodge 440 needs some wiring help. I've downloaded the schematic(s) from MyMopar.com. The schematic(s) show the wire colors, but does not show each wire's gauge. Does anyone know what gauge wire the factory used specifically at the bulkhead connector? We will be increasing the size of the wires to/from Alternator stud/Ammeter stud(in) and Starter Relay stud/Ammeter stud(out) wires adding fuse links.
What about the:
Headlamp LOW BEAM
Headlamp HIGH BEAM
RIGHT TURN
PARK LAMP
LEFT TURN
OIL PRESSURE
HORN ENABLE
IGNITION (START)
IGNITION (RUN)
WATER TEMPERSTURE
STARTER RELAY ENABLE
Thanks for any input.
What about the:
Headlamp LOW BEAM
Headlamp HIGH BEAM
RIGHT TURN
PARK LAMP
LEFT TURN
OIL PRESSURE
HORN ENABLE
IGNITION (START)
IGNITION (RUN)
WATER TEMPERSTURE
