1971 Plymouth Satellite Torsion bar bolt
3:52 PM
Austin Texas
I was replacing the bushing on my lower control arm. The bushing I bought seem to be a bit too small so I Dremel out the inside but it would still not fit onto the bar so I had to hammer it in but ruined the bolt in doing so. Where can I find the same bolt. It’s fine thread 5/8 and home depot does not have a bolt with that fine of threads.
0FD1B145-7173-43FF-8550-52293B01B062.jpeg 65E19222-96B8-4376-8F2B-07E089FD532E.jpeg 8FE28DE1-3989-48E0-9F03-B5D94D9D4831.jpeg
View attachment 925384 View attachment 925385 View attachment 925386
HD stinks for bolts.
Try a good hardware store or a industrial supply.
Try ACE.
I know they have 1/2 inch fine thread.
That my friend is a nut. Get a good quality one from an industrial supplier. Some nuts are as soft as cheese.
Next time start the nut & use a punch on the end of the shaft(inside the nut using the nut as a guide)..
I replaced all mine from Fastenal. The bolts for the lower balljoing to spindle have the same thread nuts but the ones from Fastenal are a "grip"-co style like the originals...
