Mopar Vinnie
Has anyone has used the 440 source heads and what is your build recipe with them
I'm often a "Nattering Nabob of Negativism" (thank you Spiro T. Agnew). However what is said here about the Stealth heads is true. However.............I just put a motor together last summer with them. A nice set for the money.Look just like the stock heads. Only aluminium...The guys were really helpful. I got about 100 miles on the motor. It's a beast! If it wasn't for the charging problem I'd have more miles on it.
440 with a .030 over bore
Steel crank with Icon pistons
Bullitt camshaft solid flat tappet I believe the duration 255 @ .050 the lift is .582
Harland sharp 1.5 rockers
You will have to do some minor grinding for the push rod clearance. Other than that there pretty much a bolt on product.
