That's about right. The problem with these old things ... they are VERY expensive to rebuild. Compression was ridiculously low so pistons are a "must" right off the bat. At $1500 it should sell reasonably fast. The best place to list it is on hothemiheads.com - could probably ask $2000 on there.
Yes, these are expensive to build, what Hemi isn't. I have a short block '55 331, and have 5K in it so far. Heads up will run about another 8K or so, but who cares, Hemi's are IMPRESSIVE...That's about right. The problem with these old things ... they are VERY expensive to rebuild. Compression was ridiculously low so pistons are a "must" right off the bat. At $1500 it should sell reasonably fast. The best place to list it is on hothemiheads.com - could probably ask $2000 on there.
whats the backstory on that truck?if anybody would be interested in buying it, it would be Dan. He has been doing early Hemi motors for as long as they’ve been around. Very knowledgeable guy, and very helpful. He told me to call him when I was looking at the motor, and he talked me through what to look for, and explained what I found. The one I found was set up for alcohol sand racing, he was not interested in it!
any known history?
looks like a crazy truck to be sand duning with a hemi?
